3 channel pulse generation
Discussion in 'Electronic Equipment' started by sperelat, Dec 20, 2007.
  1. sperelat
    sperelat Guest
    I need to generate pulses in ~microseconds
    in my lab.
    The pulses must be generated via 3 channels and
    I want to control width and delay of them to change
    time overlaps.
    I tried it with Labview..but analog output was too unstable,
    and digital output needed external clock.
    (Function generation input didn't work)
    I'm considering microcontroller timer/counter pin s..
    but I don't know exactly if microcontroller timer pins
    can be applied in this way.
    Does any one know circuit or device that can be
    adopted for this kind of work?
  2. If I understood you correctly, you can do this with the Dino DG535 (it is a
    design from 1986 ;-)) from Stanford.
    Have a look for the manual at www.thinksrs.com
