S
Sergey Kubushyn
Can anybody point to something available now to replace 2N4261 transistor?
It will be used in its primary role, as fast switcher.
Tim Williams said:BFT92 might be close. Don't think the t_r, t_f is spec'd, but I doubt
they use the same test circuit as the original, either (I'm looking at an
old Motorola scan for reference here). Volts, amps and frequency are
comparable. Have fun with the package though.
* KSI@home KOI8 Net < > The impossible we do immediately. *
* Las Vegas NV, USA < > Miracles require 24-hour notice. *
josephkk said:The device actually seems to actually be available (arrow) in to72 package
made by microsemi and semicoa (albeit only in expensive military grades).
Doesn't seem all that special from the data sheets i found.
It is "available" but they have none in stock. You can definitely place an
order with them for a box or more and eventually you might even get it in a
year or so.
The only real guys who do have those in stock are Freelance Electronics.
BTW, highly recommended -- they have lots of obsolete and rare parts and
those are really in stock so you get actual price right away and can
purchase them online and get them shipped next business day. Not like all
those sellers of hot air (and now many of them even show up on Octopart)
that you have to ask for a quote, give them your target price and they might
start looking for those parts usually coming out empty.
Quest has 3 (three) in stock, Freelance has more (100+) but those are pretty
expensive. I would like to buy something like 50 of those but not going to
do this for $10 a pop...
As for not being all that special -- such an expression usually means there
are many similar parts around so one can just use something else. So if they
are not all that special please point me to those similar transistors and I
will happily purchase those instead.
The closest one I'm aware of is BSR12. It works just fine in place of e.g.
2N4258 that is also used in many older Tek instruments but 2N4261 is at
least 5 times faster and I can not find anything that would've matched its
speed among modern transistors. If you know something suitable please tell
what it is.
josephkk said:Well a quick bit of hunting brought up BFT92 and BFQ75 both in surface
mount packages. Both of have higher ft though.
BFQ75 is even a bigger rarity than 2N4261. BFT92 I do know and was going to
give those a try but they are NOT switching transistors. They MIGHT work OK
for fast saturating switching but that is not guaranteed -- nobody tested
them in such applications and high Ft does not guarantee they would be as
good switchers as they are amplifiers.
Wimpie said:El 01-07-13 5:42, Sergey Kubushyn escribió:
Is it really used as a saturated switch? The test circuit below the
switching time graphs of an old Motorola datasheet (can be found on
the web) shows a long-tailed pair. This suggest non-saturated
switching times.
If it is used as saturated switch, is it really that fast as shown in
some short-form datasheets? All short form datasheets don't show the
reverse base current for measuring turn-off time.
Look at Semicoa or Microsemi datasheets. They clearly say "Saturated
Turn On Switching Time to 90%" and off to 10% (Vcc = 17V, 50 ohm pulse
generator).
And yes, it is used as saturated switch.
I can not find that old Motorola datasheet. I can only find various
Semicoa/Microsemi datasheets (some shorter, some more complete) and one
really old from New Jersey Semiconductor Products, Inc. dated June 1973.
I confess to not digging past Google 5th page but it is mostly junk
"sellers" ready to sell you any part, even one that never existed.
KSI@home KOI8 Net < > The impossible we do immediately. * * Las
Frank Miles said:There's a 3-page datasheet in the Moto "Small Signal Semiconductors" (C) 1987, starting
on page 4-172. My copy has some obvious printing defects, but definitely
gives turn-on and turn-off delays.
Fred Bartoli said:Le Mon, 01 Jul 2013 23:38:39 +0000, Sergey Kubushyn a écrit:
[dd]
Unfortunately Google won't find your copy I do not have a paper
catalog so I'm limited to only what I can find on the Net...
BTW, it is a good idea to start looking for a paper catalog. It might be
extremely handy for older equipment repair 'coz many of those older
semiconductors never made it to the Net...
Scanned and posted on ABSE...
Look at Semicoa or Microsemi datasheets. They clearly say "Saturated Turn On
Switching Time to 90%" and off to 10% (Vcc = 17V, 50 ohm pulse generator).
really old from New Jersey Semiconductor Products, Inc. dated June 1973. I
confess to not digging past Google 5th page but it is mostly junk "sellers"
* KSI@home KOI8 Net< > The impossible we do immediately. *
* Las Vegas NV, USA< > Miracles require 24-hour notice. *
