P
Paul K.
I'm working on a PSPICE simulation of a crystal oscillator using a
2N3819. So far it's working great.
I will build the circuit, but before I do, I wanted to make sure I'm
not exceeding the maximum drain-source voltage (Vds) of the
transistor. I'm putting approximately 22V across it.
However, none of the datasheets I could find listed the maximum
voltage that can be placed across a 2N3819 (from drain to source).
E.g. http://www.fairchildsemi.com/ds/2N/2N3819.pdf
Looking at a JFET tutorial however...
http://cnx.rice.edu/content/m1030/latest/
I get the impression that the drain-gate voltage is really what I
should be interested in. According to the datasheet, anything beyond
25V will exceed the device rating.
However, I'm curious though, what happens to a JFET when that voltage
rating (drain-gate) is exceeded? Does it avalanche like a MOSFET?
Would it survive?
Also, is there a reason why the drain-source parameter of a JFET is
not specified in its datasheet?
Paul
Would it survive?
Paul
