John Potter
- Nov 20, 2016
- 4
- Joined
- Nov 20, 2016
- Messages
- 4
I have a 52V transformer that after rect. produces 3.3A at 52V DC - 4.44A at 36V AC
I wish to use either a LM317 or a LM338 with 4 x 2N3055 power transistors.
If you run 2N3055's in parallel you are supposed to have a resistor like a 0.1Ohm 10W from each emitter so that thermal runaway doesn't take place. Surely the resistor should be at least the output in watts ?
There are circuits on the Internet with this resistor on the base or collector but I think the emitter is correct ?
Could you possibly tell me how to calculate the value - Ohms and watts of this resistor. ? I understand this can be critical.
Honestly the Internet can be a nest of worms, there are many circuits that don't use a resistor at all.
On her page is a link to the circuit that states she removed the 0.1 Ohm 10W resistors as it 'limited her current output'. This 20 odd Amp supply works fine.
Please advise.
I was considering using 4 x 2N3055's each at about 0.75A at 52V (39W each). I thought 3A from the transformer a safe limit. 1 heat sink per 2N3055 in an x pattern under a 125mm 0.5A fan blowing from outside the case down the heat sink fins with a 30mm gap at the bottom. The rear of the case is all vents. I may fit a 150mm 0.4A fan if the 125mm doesn't cover the heat sinks.
Mounting 2N3055's and heat dissapation.
There are 3 videos on this subject. Quite a down to earth approach but unfortunately nothing with metal to metal with heat compound - AND fan. Metal to metal with compound was by far the best. I can insulate the heat sinks. Extrapolating his results I should be able to draw 39W per 2N3055 at about 40C case temperature or less. The thermal resistance junction to case is 1.5 C/W. The max junction tempis 200C. I should be running around 60 C - or not?
Any advice would be greatly appreciated.
Please advise.
