2N2222 questions
bigkim100
Apr 17, 2013
270
Apr 17, 2013
270
Can a 2N2222 handle driving 7 LEDs, each led in parallel, and each LED having its own 180 ohm Resistor at 6Volts?, or should I be using a Power transistor??
Thank you in advance for any assistance
AnalogKid
Jun 10, 2015
2,884
Jun 10, 2015
2,884
Ohm's Law plus third-grade arithmetic. In order:
What is the circuit voltage?
What is the voltage drop across an LED (Vf)?
What is the voltage across the resistor?
What is the current through the resistor?
What is the total current through all resistors?
What is the collector current rating of the transistor?
Therefore . . .
ak
Nanren888
Nov 8, 2015
622
Nov 8, 2015
622
Liked this ...
But, out of interest, what makes you think 180 Ohms is the correct value? (Probably right, just interested in how it came about)
If this was to set some current, then maybe you already know the current per LED (and resistor)?
The analysis above still applies, but that current might also act as a check.
AnalogKid
Jun 10, 2015
2,884
Jun 10, 2015
2,884
The OP set the resistor value, not me. We have zero information about the LED or the desired current level, so there is no way to evaluate the appropriateness of the resistor value.
Current levels in the LEDs, the resistors, and the transistor are three different things. The question was about current in the transistor, and that is what I answered.
Note: For improved long-term reliability, do not operate the transistor at more than 50% of its rated continuous collector current spec. (I wanted to add this to my initial response, but this forum has a too-short time limit on editing.)
ak
Nanren888
Nov 8, 2015
622
Nov 8, 2015
622
No criticism intended. I'll leave it in your capable hands. :)
ramussons
Jun 10, 2014
462
Jun 10, 2014
462
If that 2N2222 is being used as a switch, you can safely pass 800mA through its collector.
AnalogKid
Jun 10, 2015
2,884
Jun 10, 2015
2,884
Not really. I disagree with "safely". 800 mA pushes the device to its absolute limit, and requires that the package be maintained at a relatively low temperature. Yes, it will work - for a short while.
1. 800 mA is its "Absolute Maximum" collector current rating. No device should *ever* be operated continuously under any of its listed "Absolute Maximum" conditions.
2. The condition requires that the device be maintained at a *case* temperature of +25C. This required a heatsink, because ...
3. At 500 mA, the max rated saturation voltage is 1 V, for a device power dissipation of 0.5 W. That is a *lot* of heat for such a small package. The case temperature will literally melt your fingerprint.
The highest collector current mentioned in the parameters tables is 0.5 A. For long-term reliability in uncontrolled conditions, best to operate this part at 300 mA or less.
ak
PETERDECO
Dec 19, 2019
239
Dec 19, 2019
239
The way I see it assuming the LED is a 2V with a series 180 ohm resistor, current consumption will be about 22mA. Multiply by 7 LED's which brings it up to a little over 150mA. I think a 2222 can safely do this.
