280V motor on 230V circuit
Discussion in 'Electronic Repair' started by Deodiaus, Apr 26, 2008.
  1. Don Kelly
    Don Kelly Guest
    Fair enough- but still overkill. For the bulk of the calculations that one
    does, single precision is more than adequate. Anything more, even for
    comparison of numbers is really fluff.
    I simply set my display to show the desired sig figs and let the calculator
    deal with the rest in its normal internal mode. I don't want to see the
    extra digits, or , if I do, 1 or 2 is sufficient. Ditto with the computer.
    Only if I am dealing with ill conditioned sets of simultaneous equations ,
    will I really require double precision.
  2. bz
    bz Guest
    pounds (mass), lbm, as opposed to pounds (force), lbf, or lb.
    It is necessary to distinguish between mass and force but they are both
    measured in pounds in the english system.
    Metric is 'much simpler' with grams(mass) and newtons(force).
    bz 73 de N5BZ k
    please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
    infinite set.
    remove ch100-5 to avoid spam trap
  3. krw
    krw Guest
    The "English" system uses the "stone" as the measurement of mass.
    The pound ('lb') is the unit of *FORCE*.
    Evidently *you* think the "English" system is too complicated. ;-)
  4. bz
    bz Guest
    http://www.engineeringtoolbox.com/mass-weight-d_589.html
    I don't think any of them are 'too complicated'.
    It is easy enough to convert from one to another.
    However, FAILURE to convert has been known to cause problems, such as a
    Mars mission that crashed because the wrong units were used.
    http://www.cnn.com/TECH/space/9909/30/mars.metric/
    bz
    infinite set.
  5. charles
    charles Guest
    The 'Stone' is a unit of mass, not "The unit of mass"
    All the engineering I ever learned in the British (Imperial) system used
    pounds.
    No - the modern Metric system uses the kilogramme as its fundamental unit.
  6. krw
    krw Guest
    It is *the* unit of mass. The pound-mass is a recent abortion.
    You must be a kid.
    Only if you spell funny.
  7. charles
    charles Guest
    cleverly, we use the same word for two different things to confuse
    foreigners.
  8. charles
    charles Guest
    No - 68!!!
    Even in 1961 the MKS system was the norm.
  9. bz
    bz Guest
    Really gets to be fun when working with things like foot-pounds,
    as in torque, angular momentum, and the pressure due to a certain depth of
    water.
    Trying to remember when the pounds are mass and when they are force gets
    to be fun.
    bz 73 de N5BZ k
    infinite set.
  10. krw
    krw Guest
    I first heard pound-mass about ten years ago. All through high
    school and college the English unit for mass was the stone (as in
    the FSF system of measurements).
    Sure, but you still spell like a frog. ;-)
  11. Don Kelly
    Don Kelly Guest
    In the early '50's there were two other units around- the poundal (1/g
    pounds force) or a mass called a slug (g pounds mass). Learning mechanics
    with these units (don't use them together)is worse than working in the
    stone, furlong, fortnight set of units.
    The poundal was introduced in 1879 as part of the "english set of units"
    (Wikipedia is sometimes useful).
  12. charles
    charles Guest
    I certainly remember the poundal.
    The various old english measures: chain, rod, quarter, peck, etc, were, of
    course, very useful to teach children arithmetic since they all came with
    different bases.
    and of course you can measure viscosity in Acres per year - if you want to.
  13. Ian Jackson
    Ian Jackson Guest
    You forgot the poles and perches, the bushels, and of course, the LSD.
  14. Guest
    | charles wrote:
    |>> says...
    |> pounds.
    | I always thought the British pound was a unit of currency. :)
    That's why I never wanted to carry around the British currency. It can be
    quite a chore to carry 50 pounds in your pocket :)
  15. charles
    charles Guest
    that saying must be some years old.
    A pint's now about three pounds ;-(
  16. Also a US pint (16 fl.oz) is smaller than an Imperial pint (20 fl.oz),
    so that would make beer more expensive in the US ;-)
  17. David Lesher
    David Lesher Guest
    Just wait until you run into BTU's....
  18. David Lesher
    David Lesher Guest
    The pole pigs here [7200v in/120-240 out] are fixed tap, I'm told. Saves
    money. I think they are fused at 10A in. Older ones may have settable taps.
    Capacitors are in various places but we also have three 7200V line
    regulators a block away, one on each primary phase. They are
    auto-transformers, with allegedly auto-controlled tap changers, much as
    the other poster described. [But his description is more complex than
    I recall from the class covering same. The essential aspect was you
    CAN short two taps together while switching; the inductance limits the
    current change while you do..]
    I say "allegedly" as twice now, the regulators have stuck and my UPS
    woke me up at 2:30AM with notices it was disconnecting from the now-128v+
    line. I solved the issue that night by putting a Variac in the line
    ahead of it, and cranking it down.
    It took multiple calls and finally PSC [oversight agency] complaints
    to get PEPCO to fix the damn thing.
    I envy EU houses. If we had regular 240V/30A+ outlets, I'd be able to
    buy a snowblower with real guts. The [email protected] ones are wimpy.
  19. Guest
    |>All distribution transformers, sometimes called "pole pigs", that I
    |>have seen had some sort of voltage adjusting system, usually referred
    |>to as taps. Usually they are an actual bolted "tap" and you open the
    |>transformer and set the output voltage by making the proper tap
    |>connection when the transformer is installed and frankly it is usually
    |>ignored thereafter.
    |>The other "cans" you often see on poles are capacitors used to adjust
    |>the power factor on some secondaries.
    So put one in.
  20. David Lesher
    David Lesher Guest
    The issue is not the outlets available in my house [but I sometimes wish
    for 3 phase..].
    Rather, it's the ready market of consumer appliances that would take
    advantage of them. That would require many houses to have them.
