Yes, 12V at 30mA would be fine for that cable.
See
here.
I presume you're using 40 leads to go to individual modules, and the remaining 10 as common ground.
Are the LEDs in series or parallel. If they are in series it's all OK. If in parallel, then you would want to ensure the ribbon cable was not coiled up or otherwise unable to radiate heat.
