260 Mulitmeter
Discussion in 'Troubleshooting and Repair' started by Jimmie, Jan 19, 2016.
  1. Jimmie
    Jimmie
    13
    Jan 6, 2016
    I have a Simpson 260 series 3 that works on all functions except the RX 1 ohms position. I have check and replaced all batteries. Clean all contacts in and out. the other two ohms connections work. also check all resistors.
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Look at the Pic below:
    The unique paths for the Rx1 are the 3 switch contact positions number 10 (marked red) and a single wire (marked green).
    Check them for discontinuity.
  3. Jimmie
    Jimmie
    13
    Jan 6, 2016
    Thanks again. Your schematic help a lot. Red wire had loose solder connection. Works fine now.
