250W amp - Mark Bass , Little Mark 250, of 2008, Italy
N
N_Cook
A dropper will go in with changed 1uF and new sacrificial IRF740 tomorrow
1KHz RLC testing of the Tx
feedback coil .039mH
240V tap 2.37mH to gnd
230V tap 2.22mH
100V 1.8mH looks reasonable
Along the way that Zener3 in the 200+220V zener chain is probably 6.2V (at
low uA level) and the 2N7002 (SMD topcode mark 782 R) functions as it should
F
Franc Zabkar
AISI, the 2N7002 FET should be off in normal operation, so I think
you're wasting your time in this area. If you're concerned about the
"Drive IC's" Enable pin, then disconnect D37.
- Franc Zabkar
N
N_Cook
Franc Zabkar said:
should
- Franc Zabkar
I agree, there is another associted point. There is no jumper configuration
in that area for 100/120V countries so must be completely inoperative , in
mormal operation, in those countries
N
N_Cook
I suppose for this amp only used in 240V land, then replacement SMPS driver
powerFETs only need to be rated 600V/10A and for such an amp only in
100/110/120V land then 300V/20A rating
P
Phil Allison
"Nut case Kook is off his rocker "
** ROTFLMAO !!!!!!!!!!!!!!!!
Go look at the fucking CIRCUIT !!
Idiot !!!
N
N_Cook
I've acquired a new IR2153 and desoldered the original unkown driver and as
the Tx primaries are some distance from the driver IC, soldered in a turned
pin socket. The old one has Thailand and R3 mould marks on the underside and
perhaps the second line on the top starts with a 7 and the third line ends
with a 5 . I'm assuming there was a top line that is well ground out.
Will power up with a couple of droppers in there with 60 percent mains ,
still set on 240V jumper.
I can now compare old and putative replacement
N
N_Cook
A bit further forward I suppose. Exactly the same, for 2153 and original,
audible low level oscillator noise , 10 seconds or so after switch off
presumably coming down from ultrasonic and dropping in pitch over a couple
of minutes while there is HV in the main caps. And +/-0.5V on the main rail
caps transfered across the Tx from the startup pulses, instead of the +/-60V
or so . But no sustained drive. Next is some monitor of the Tx primary
feedback route to the driver and somehow monitor the osc f, perhaps change
the SM cap is easier, the SMRs measure ok. Any tricks for fooling the driver
into thinking there is more feedback than actual, a battery wired-in?
F
Franc Zabkar
JP1 in the bridge rectifier area configures the unit for 240VAC
operation when open, and 120VAC when closed. In the latter case the
circuit becomes a voltage doubler.
Therefore Vdc = 350VDC in both configurations.
- Franc Zabkar
F
Franc Zabkar
I would have done a bit more testing before I opted for the 2153.
For example, I would have disabled the "Driver IC5" by shorting the
drain and source pins of T24 with a blob of solder (assuming a GDS
pinout). This would allow the Vcc capacitor (C52) to charge to the
IC's internal zener voltage. You could then compare this voltage
against the datasheet.
If the IC is oscillating, then this frequency may also provide a clue
to the chip's identity.
- Franc Zabkar
F
Franc Zabkar
I'm having some difficulty understanding your plan, but first allow me
to explain how I think the circuit works. If I'm wrong, someone will
hopefully correct me.
Firstly, I would not attempt to substitute a battery for the
"feedback" voltage. This will defeat the IC's overload protection. If
you are going to do this, at least disconnect the 1uF capacitor (C68).
Also, instead of a battery, you could add several 270K feed resistors
between Vdc and Zener3. Then monitor the IC's Hi and Lo outputs. That
should at least give you some confidence in the IC.
As for how the IC works, I believe it would have a start mode and a
run mode. In the start mode it would draw a very small current,
probably less than 1mA. This would allow the Vcc capacitor (C52) to
charge. When Vcc exceeds the undervoltage lockout threshold, the IC
switches to run mode. It then attempts to kickstart the supply by
pulsing the MOSFETs. In run mode the IC would draw more current than
can be provided by R78, in which case C52 would begin to discharge. If
a regenerated supply cannot be developed from a secondary transformer
winding via D34, C69, D21, and C70, then C52 will discharge to below
the lockout threshold, causing the IC to revert to start mode. C52
then charges once again, and so on.
Therefore, if there is an overload on the secondaries, the regenerated
supply never eventuates, and the IC hiccups. Some IC's will count the
number of hiccups and shut down completely if there are too many
attempts.
- Franc Zabkar
N
N_Cook
- Franc Zabkar
I am getting very inconsistent poor to bad ESR with electroC69 so will
change that and C70.
N
N_Cook
The 2153 has Thailand in a dimple on the rear of the package and an empty
dimple on the diagonal, this structure the same as the ground off one, minus
the R 3 .
I wonder how many IR 8pin , that pinning packages , were available in 2008
and a year or two before. Unfortunately I don't like using isolation
transformers and scopes on SMPS to narrow down a bit more, if I regularly
dealt with SMPS failures then perhaps it would be different. If this one
wasn't a lot of difficult to probe SM around the DIP8 SMPS driiver ,hemmed
in by heatsinks and large caps then may have been different
F
Franc Zabkar
Those capacitors are a common reason for failure to start. Sorry, I
assumed you would have checked them.
- Franc Zabkar
N
N_Cook
- Franc Zabkar
So that 220/220V zener chain is perhaps more for the possibility of someone
jumpering JP1 to 100V and plugging in to 240V and instead of 350V dc trying
to get to 700V dc
Have got inundated with more normal stuff and this Mark will have to wait a
few days
N
N_Cook
I now see someone else has been here before and ground off IC5
music-electronics-forum.com/t10881/
What is the difference between IR2153 and IR21531?
The original has a diode between Vcc and VB so perhaps whether 2153 or 21531
or any other IR it should be the D variant or adding a high voltage diode
externally
F
Franc Zabkar
to get to 700V dc
Ah, that would make sense. I was wondering why there was a 275V MOV
across A-N, since that voltage would be below the overvoltage
threshold for the zener chain.
- Franc Zabkar
F
Franc Zabkar
Did you see the following post in that thread?
Have you noticed that pins 1 and 4 (Vcc and COM) of IC5 are reversed
on the schematic (if this is IR21531)?
I noticed on the one i'm working on. I was hoping it was an error in
the schematic but it is not.
I verifyed continuity to ground at pin 1.
So the IR21531 is not a drop in replacement as far as I can tell. I
have looked at just about every self oscilating half bridge drive they
sell and nothing that has pins 1 and 4 swapped.
- Franc Zabkar
F
Franc Zabkar
Sorry, I should continued reading. It appears that they are indeed
reversed.
- Franc Zabkar
N
N_Cook
- Franc Zabkar
I'll sling a 4007 under the board beefore powering up again. As my 2153
started pumping out some pulses and oscillated , at least in audible range
with low Vcc, then I can assume pins 1 and 4 are not as in that Mark Bass
schematic.
Something else I've noticed on SMPS generally before but not thought about
why. Around the elevated mains voltage area a line of slotted perforations
in the pcb material. This must be more expensive to produce than a hatched
wide line of white ink at the overlay stage. I cannot see ventilation or a
paliative to possible developement of conductive pcb material as being the
reason
N
N_Cook
reversed.
- Franc Zabkar
Just checked again
The polarity pip of the original was not ground off and p1 is connected to
the dropper from the + of the HV dc caps , ie Vcc and p4 is connected to the
zero/negative of the HV caps (not ground of course) . So someone getting his
pin convention wrong I think, overlay "pip" is obscured by the chip and
agrees with the original orientation of the chip
