25 PF Capacitor sub
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
A circuit I am building calls for a 25 pF capacitor. There is no polarity shown, so I assume it is a film capacitor. It is a guitar pedal distortion circuit.
I don't have 25 pF capacitiors . You'd think with all these kits I bought I'd be able to cobble one up, but I am not sure I can. Does anyone see anything in there I can use?
I have the following kits:
https://www.amazon.ca/gp/product/B01GFE11ES/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.ca/gp/product/B07D1J5LSD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.ca/gp/product/B07F7ZN695/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.ca/gp/product/B00OJPU24Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.ca/gp/product/B07K7NLSH2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
kpatz
Feb 24, 2014
334
Feb 24, 2014
334
What's the smallest capacitor you have? The smallest in the kits you linked (your 1st link) are 100pF.
If you have a couple 12pFs you could parallel them.
In a pinch you could connect 4 100pF caps in series to get 25pF but that's a kludge.
Maybe find some locally (if you have any electronics stores in the area) or try Digikey/Mouser.
bertus
Nov 8, 2019
3,303
Nov 8, 2019
3,303
Hello,
Show the schematic.
It can be the value is not that critical.
If you really want 25 PF, take the 10 and 15 PF capacitors from kit 3 in parallel.
Bertus
Ylli
Jun 19, 2018
401
Jun 19, 2018
401
The application is not critical, either value would be OK. It I had to choose, I would go with the 27 pF.
kpatz
Feb 24, 2014
334
Feb 24, 2014
334
Ditto, the difference will be negligible if any. I think it's just to prevent the 741 from oscillating at high frequencies, by damping them. Basically a low-pass filter, with a high cutoff judging by the small capacitor being used.
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
Thanks guys. i used the 27pF. Bertus, thanks for the article. I am making it a point to go back to this circuit once I compete it, and begin to understand it theoretically. I think that is an important part of my learning. Otherwise, i am simply doing a paint by numbers thing.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The 27pF capacitor parallel with the 1M opamp's negative-feedback resistor simply cuts audio frequencies above 1 divided by (2 x pi x 27uu x 1M)= 5926Hz at -3dB, making sounds a little muffled. R6 and C5 also cut frequencies above 1 divided by (2 x pi x 10k x 1nF)= 16kHz at -3dB.
I never calculate with 2 x pi since 1 divided by 2 x pi is simply 0.16 times. So 0.16 divided by (27uu x 1M)= 5926Hz and 0.16 divided by (10k x 1n)= 16kHz.
