Hello,
I would like to investigate the different 24VDC LED lighting distribution systems that are currently available on the market as we have to plan a large office building lighting system.
I simply cannot find the offerings which i know must be out there in this field. I wish to compare prices
Do you know of any 24VDC lighting systems.
Eg, Mains to the building, then power converter, then 24VDC distribution wires to the separate lamps.
Clearly its more efficient to do PFC in a centralised unit placed eg in the basement of the building, and then distribute DC to lamps from this point. Theres also the advantage of easy interconnection with solar power.
Obviously one cannot use >24V as it creates too much contact sparking in connectors which wears them out unless they are very expensively made.
