24VAC UL FIRE Powersupply
D
Duncan
Does anyone know where to track down a 24VAC UL Fire power supply? At
this poin, I don't care how many amps it has. None of the "big names"
have them...
R
RockyTSquirrel
I use Firelite products.
But you could also try any door holder/access PS..
Also some CCTV combo PS's have high current units.
RTS
F
Frank Olson
have them...
If all you're looking for is 24VAC, I would imagine any UL Listed
Transformer will do. I do know that a large number of "24VAC" fire
alarm systems are out there. Most I've seen use a standard
off-the-shelf transformer in whatever flavor best suits the installation
(current wise, etc.).
jewellfish
I just have to ask, "what are you going to do with this 24 volt ac
transformer that you need it to be UL listed for ( I assume
commercial) Fire use?
Regards,
Bill
F
Frank Olson
Regards,
Bill
There are a number of older non-coded fire alarm systems out there.
Edwards made more than a few. They use 24VAC (or 12VAC) with a 12VDC
non-rechargeable (and unsupervised) battery. They also used a three
wire system with the "common" for both the bells and pull stations/heat
detectors. Another well known manufacturer (at least here in Vancouver)
was Pacific Protective Systems. The units fulfilled a basic need but
advances in technology made them all obsolete pretty quickly.
Now-a-days unless the AHJ absolutely insists on replacing the units with
a supervised fire alarm system, the "old workhorses" stay pretty much
where they are. As long as they pass the annual inspection (ring the
bells when required) all we can do is recommend the customer consider
upgrading. We recently had to replace an annunciator on one of the
Edwards units we service. Parts are no longer available and there's
nothing "off the shelf" that will work, so we had to build one
ourselves. We made it as a ladder graphic (which is far better than the
"presentation" they had originally). We also used LED's instead of the
incandescents (each of which was individually fused) and prone to
failure due to weather (unit was mounted outside and we're living on the
"wet coast"). The only things the AHJ insisted on (in addition to
identifying the individual floors) was an "AC Power" LED and a "lamp
test" button (which the old annunciator didn't have). Took a bit of
"doing" but we used the schematic Edwards provided to design the circuitry.
R
Robert L Bass
Probably powering 24 VAC smokes for use in hotel guest rooms or
individual apartments (not the common areas).
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-232-0791
Fax 941-870-3252
