24v Keypad - Microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by Sadlercomfort, Dec 9, 2015.
  1. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Hi guys,
    Does anyone know how to interface a 24v keypad to a microcontroller.
    Usually I would use a 5v keypad and connect it directly to one of the ports with pull up resistors. However I can only find a 24v one for cheap on farnell so I have to use this.
    http://www.farnell.com/datasheets/1804053.pdf
    Is this a 24v max rating? Or do i need to use 24v?
    Ash
  2. Minder
    Minder
    2,953
    623
    Apr 24, 2015
    Those KB's are passive devices, just tactile switch so 5v or 24v does not really matter, they are set up with a matrix to save on I/O, see the tutor series by Nigel Goodwin Tutorial site.
    M.
  3. Sadlercomfort
    Sadlercomfort Ash
    424
    53
    Feb 9, 2013
    Oh okay,
    So its safe to say i can use anything from 5V to 24V.
  4. Minder
    Minder
    2,953
    623
    Apr 24, 2015
    As long as you observe the 50ma rating.
    Correction, I see they have a ilumination LED they mention 5v for these?
    Separate connections.
    M.
    Sadlercomfort likes this.
  5. Minder
    Minder
    2,953
    623
    Apr 24, 2015
    To follow up it appears that the keyswitches are anything up to 24vdc rated, the diode anode/cathode is 5v, I am assuming that there is internal series resistors, it does not mention the inner connections.
    M.
