Without knowning anything about the device, it's hard to say.
However, note that many devices these days use switchmode
power supplies, and these sometimes include a control to change
between 120 and 240 volts. These controls are deliberately made
small and recessed so they can't get changed accidentally.
Look for a small recessed rectangle with a screwdriver slot that
operates a slide switch, or sometimes a recessed circle for a
rotary switch. The 2 positions should be marked. You may also
need to change power cords to match the outlet.
The above comments particularly apply to computers, monitors, and
such that have power cords that can be unplugged from the device.
(That's how the manufacturer deals with the different voltages and
plugs.) The switch will usually be very near that.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
