24 bit math so I can read and write
Discussion in 'Electronic Basics' started by Randy, Mar 27, 2007.
  1. Randy
    Randy Guest
    I am writing and reading to a microcontroller.
    My largest allowable variables are 16 bit and 8 bit
    How can I write a 24 bit value when I am limited by 16 and 8 bit
    variables?
    For instance I need to send a register value of HEX 200110 which is
    configured for 24 bits.
    This is equal to 2,097,424 in decimal format.
    How do I divide this up into a 16 and 8 bit or 3 8-bit variable values
    to send and receive?
    I can send it HEX or Binary.
  2. James Beck
    James Beck Guest
    You hit on it below.
    You read/write 3 8 bit pieces.
    Well it kinda' depends.
    How is the variables laid our in memory?
    If it were an HC05 part I would know the variable is most likely stored
    as three 8 bit values with the lowest address holding the upper byte
    address+1 is the middle byte and address+2 is the low byte.
    Other CPU/MCUs do it just the opposite.
    Google "big endian" or "little endian"
    Now, all you have to do is send those 3 bytes and you are done.
    If you are using a high level language that supports INT24s then the
    task is even easier. Just do shifts and mask off the byte you want to
    send.
    Jim
  3. Randy
    Randy Guest
    Jim, I am using a Basic Stamp BS2.
  4. Noway2
    Noway2 Guest
    If the platform you are using does not support numbers large enough for
    your needs, then you need to roll your own routines. A while back, I
    worked on an application that performed 24 bit arithmetic with an 8 bit
    Motorola 65xx series processor. The math routines were modeled after
    the grade school methods of long hand multiplication and division.
    As far as transferring or storing data, it doesn't matter what format it
    is in. To the computer it is all the same. You need to decide on the
    protocol that will be used between the devices. The data doesn't
    matter, the key is how it is interpreted.
  5. James Beck
    James Beck Guest
    OK, what are you sending this 24bit data to and how is it being sent
    (uart, I2C, so on).
    Jim
  6. John
    John Guest
    You might want to check on the PICAXE forum
    http://www.rev-ed.co.uk/picaxe/forum/forum.asp?forum_id=30&forum_title=PICAXE+Forum
    There's been recent discussion on how to do 24 (and 32) bit
    arithmetic. Since the PICAXE is programmed in a dialect of BASIC, the
    conversion to Stamp should be relatively simple.
    John
  7. James Beck
    James Beck Guest
    I might have been a bit slow, BUT I think he is trying to write to some
    type of device's configuration register. If that is the case just hard
    coding the three bytes into the code would be good enough to get by. I
    think what threw me was the "math" word.
    Jim
