W
Winfield Hill
I'm back to finalizing my design for a "dual 24-bit 100kHz A-D
converter with optical s/p-dif output," after taking some time
away to struggle with refining a PCB design for a 400MHz 14-bit
precision balanced DDS generator for the same project.
My 24-bit A/D design was "completed," with its schematic captured
and edited to maturity a few weeks ago, and now I'm back working
on it, ready to pre-position the parts on the PCB before sending it
to my layout gal. So the time for making any changes is rapidly
coming to a close, and I find my confidence is faltering. Have any
of you folks done any designs with these new-fangled 24-bit delta-
sigma converters, and if so did you learn anything I should know?
http://www.cirrus.com/en/products/pro/detail/P1024.html
http://www.cirrus.com/en/products/pro/detail/P1009.html
I'm using the Cirrus-Logic cs5381 and cs8406 chips, operated from
a well-filtered and bypassed 5V linear supply, using 3.3V logic,
and driving the A/D balanced inputs with balanced LT1468 opamps.
These chips want 2700pF right on their input (!), so I'm using the
standard high-speed opamp capacitive-load circuit.
The 100kHz output rate is created using a 12.8MHz PLL oscillator
working from an external stable 10MHz reference, with special care
taken to insure a Philips 74hct9046 PLL chip is working in a quiet
environment to reduce jitter.
