22K Log conductive plastic pot
Discussion in 'Electronic Design' started by Ian Bell, Mar 11, 2010.
  1. Ian Bell
    Ian Bell Guest
    I am looking for a UK source of a 22K or 25K log panel mounting
    conductive plastic or cermet pot. I have checked Farnell, RS, Rapid and
    Maplin to no avail.
    Cheers
    Ian
  2. Phil Allison
    Phil Allison Guest
    "Ian Bell" <
    ** Use one of these 50K dual linear pots:
    http://uk.farnell.com/vishay-sfernice/p9a2r100fisx1503ma/pot-linear-dual-50k/dp/8791368?Ntt=8791368
    Connect the two sections in tandem - ie, the wiper of the first goes to the
    top of the second.
    The law is then close to log.
    10% = -40dB
    25% = -24dB
    50% = -12dB
    70% = -3dB.
    ...... Phil
  3. Ian Bell
    Ian Bell Guest
    Thanks for that Phil, it is something I had considered and it has the
    advantage that the law is much more repeatable. Unfortunately I should
    have been more specific about the application and in this case I need
    the log(ish) law but it is not to be used as a potentiometer but as a
    variable resistance (in an equaliser). As far as I can see, cascaded
    linear pots do not give that - for example the total resistance from the
    second wiper to ground at the 50% point is 10K. Is there some other way
    of connecting a pair of linear pots to give an approximate log law
    resistance between two terminals??
    Ah, I just realised if I connect the second wiper to its upper terminal
    I get 6.25K at the mid point - that might just do it.
    Cheers
    Ian
