220v to 110v circuit
Discussion in 'General Electronics Discussion' started by Scott Hewitt, Feb 11, 2016.
  1. Scott Hewitt
    Scott Hewitt
    3
    Feb 11, 2016
    Hello all I have a small temperature controller that was made in Europe and has the euro plug. I tried using a plug converter but the output is only 58v where I need 110. Do you think this is something that a component or two change on the board would make this work on 110.
  2. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    Is this a thermostat device of some kind?
    Is there heating elements involved?
    More would have to be known about the device itself.
    M.
  3. davenn
    davenn Moderator
    13,866
    1,958
    buy an appropriate step-up transformer
    they are readily available for people wanting to match 110V required by the unit to local mains voltages
  4. Scott Hewitt
    Scott Hewitt
    3
    Feb 11, 2016
    It has a probe that reads the temperature and then adjust the output to a heat pad.
  5. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    He needs step down. 230v - 120v
    M.
  6. Scott Hewitt
    Scott Hewitt
    3
    Feb 11, 2016
    But it's made for 220 and I'm plugging it into 110
  7. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    It appears to have a switching supply, you could try it on 120.
    Although the unit is rated at 600w the current for a local supplied 600w pad would be twice the current.
    Will be 1/2 if original pad..
    Max.
  8. davenn
    davenn Moderator
    13,866
    1,958
    yes so you need a step up transformer, as I stated :)
    you misread his requirement
  9. Colin Mitchell
    Colin Mitchell
    1,416
    313
    Aug 31, 2014
    Don't you have 220v in the United States of Obama.
  10. BobK
    7,682
    1,688
    Yes, we do, but only 2 outlets in a typical house, one for the stove and one for the dryer.
  11. Tha fios agaibh
    Tha fios agaibh
    2,166
    726
    Aug 11, 2014
    Similar to a post not long ago called "thermostat".
    I believe it was Duke37 who suggested changing the incoming capacitor in order to increase the internal voltage of the circuit.
  12. Tha fios agaibh
    Tha fios agaibh
    2,166
    726
    Aug 11, 2014
    :D
    Even better, we have 240v.
