My buddy sent me this. Just curious.. Are precautions like this common for these beasts? It reads like handling RA Isotopes!
Check out the precautions for use on these 1 watt LEDs!
http://www.mpja.com/20-lm-1-Watt-BLUE-Star-LED/productinfo/19586 OP/
Precautions for use:
1. Storage
To prevent moisture absorption into High-power LEDs during the transportation and storage , the LEDs are
packed in a moisture-barrier bag. Desiccants and a humidity indicator are packed together with the LEDs as secondary protection
The shelf life of LEDs stored in the original sealed bag at <40°C and < 90% RH is 12 months. Baking is required if the shelf life has expired
Before opening the packaging , check for air leaks in the bag.
After the bag is opened, the High-power LEDs must be stored at <30°C and < 60% RH. Under these conditions,
High-power LEDs must be used within 24 hours. If the LEDs are not within 24 hours after removal
from the bag, baking is required. Take the material out of the packaging bag before baking. Do not open the
oven door frequently during the baking process.
2. Soldering
(1) Manual soldering with a soldering Iron
Use a soldering iron of less than 25 watts is recommended . The iron temperature must be kept below 315°C
And soldering time no more than 2 seconds.
The epoxy resin of an High-power LED should not contact the tip of the soldering iron.
No mechanical stress should be exerted on the resin portion of an High-power LED during soldering.
Handling of an High-power LED should be done only when the package has been cooled down to below 40°C
