it depends on the capacitors and the number of stages.
here is a simple calculation
V
out = (V
in x 1.414 x n) - (I x (n
3 + (9 x n
2 / 4) + (n / 2))) / (12 x f x C)
where
- Vout is the output voltage
- Vin is the input RMS voltage
- n is the number of stages
- I is the current draw in Amps
- f is the input frequency
- C is the capacitor in farads
So, for 20 stages, and a 350VRMS AC input, 0.1uF capacitance 60Hz...
Open circuit (zero current) will give you about 9.9kV
at 0.01mA, you'll have an output voltage of about 8.6kV
So you'd probably be safe draw up to 10uA without the output dropping to less than 80% of your expected voltage.
What value are your capacitors? What current do you need?
