200v 50a arc lamp PSU again :)
Discussion in 'Electronic Design' started by John Barrett, Mar 4, 2007.
  1. John Barrett
    John Barrett Guest
    There has been some mention of using an arc welder to power a krypton arc
    lamp rated at 8000w (200v/40a.. make it 50a for a little headroom)
    I was under the impression that arc welders operated well under 200v output,
    and was wondering if someone could explain either A> how an arc welder works
    such that i could produce the output I need, or b> what modifications might
    be neccessay to get the desired output ??
  2. Yes, typically around 30 - 90 volts IIRC. You CAN get a shock off them if
    you are wet and grounded.
  3. John Barrett
    John Barrett Guest
    we knew this already -- I do plenty enough with my 120v arc welder on my
    trailer mounted antenna tower -- do you have something to contribute that is
    more in line with the question ??
  4. Moron.
    PLONK!
  5. John Barrett
    John Barrett Guest
    dont waste my time -- say something relevant to the question.
  6. Genome
    Genome Guest
    Fuckin A!!!!!!
    Plonked by Homer......
    Fuckin A++++++++
    **** life is just tooooooooo fucking good.
    DNA
  7. Yeah. They have to be extremely stupid for that but this dumbfuck achieved
    that level of failure.
  8. Genome
    Genome Guest
    Hang on.
    You plonked me earlier over your inability to deal with fly by wire.
    DNA
  9. John Barrett
    John Barrett Guest
    If wanting a responsive answer is all it takes to get plonked around here --
    then I AM PROUD TO BE PLONKED !!
    Its not MY fault that you dont know enough about arc welder internals to
    answer my question !! (or if you do, that you choose to give me shit rather
    than answer my question !!)
  10. maxfoo
    maxfoo Guest
    Go ask your question in 'sci.engr.joining.welding'
  11. You seem to be confused.
  12. Genome
    Genome Guest
    Newsgroups: sci.electronics.design
    Date: Fri, 13 Oct 2006 00:36:59 GMT
    Local: Fri, Oct 13 2006 12:36 am
    Subject: Re: Did Europe's new standards for pc boards ground Airubs?
    Reply to author | Forward | Print | Individual message | Show original |
    Report this message | Find messages by this author
    PLONK!
  13. "Fly by wire" is done with hydraulics. Have you not noticed what happens
    when all of the hydraulic fluid in a plane's control system is lost?
  14. jasen
    jasen Guest
    mee too.
    It's basically a big transformer.
    connect the outputs of two (or three?) in series?
    Bye.
    Jasen
