2008 lost LED mons while rained
Discussion in 'Electronic Repair' started by [email protected], Aug 4, 2013.
  1. Guest
    In Dec 2008 I lost two LED monitors in one week. There was light rain in
    both cases but nothing got wet. I mentioned this to other people said this
    happened elsewhere. Two insisted it happened to them, and others were
    hearsay. The same week!!??
    I would appreciate a rational explanation
    Vasos Panagiotopoulos, Columbia'81+, Reagan, Mozart, Pindus, BioStrategist
    http://www.panix.com/~vjp2/vasos.htm
    ---{Nothing herein constitutes advice. Everything fully disclaimed.}---
    [Homeland Security means private firearms not lazy obstructive guards]
    [Urb sprawl confounds terror] [Phooey on GUI: Windows for subprime Bimbos]
  2. Jeroni Paul
    Jeroni Paul Guest
    If you bought them at the same time and they saw similar use it could be they reached the end of their service life.
  3. Leif Neland
    Leif Neland Guest
    Jeroni Paul har bragt dette til verden:
    You mean the warranty timer? Set to go off 13 months from purchase :)
    Leif
  4. Guest
    "What's an LED monitor? Is that an LCD monitor with LED backlighting
    or did you mean an LCD monitor?"
    Yes, that is what the civilians call them. In fact that's what it says on the box usually.
    That could be alot closer to the truth than most people realize. When you buy the components in very large quantities and they are all exactly the same it makes it almost possible to get it down to a couple of months, semi-reliably. In fact that brings up a topic I am going to start in SED about just that. I'm glad this took that direction which remonded me of it. Collegues in the repair field don't see it but I have pretty good evidence that there is a planned failure of software due to ESR in a certain filter.......
    However I do not believe that is the case here. I believe it was luck of the draw actually, even if the actual fault turns out to be the same in each unit. the OP did not specify if they were the exact same model.
    Even if the humidity got to ridiculous levels I am still going with luck ofthe draw because in an LED backlit set there is only a couple hundred volts across each string. In a CCFL backlit set, of a certain model I could go with environmental factors. IIRC there were some Emerson (et alii) models that had problems with part(s) of the backlight array shorting out, which made the inverters look bad. The design was such that you could not disconnect each lamp separately so it wasn't hard to get a bit tripped up. Gawd i amsick of brownwares but after my recent experience with that Tektronix....LOL
  5. Guest
    One was on a Compaq Aero 4/24 I got used. THe aero was the best laptop I
    ever used. Ev'tho only DOS, but it was perfect for most things.
    THe other a year old siemens monitor. I'm thinking geomagnetic storm because
    they both used transformed DC power. Remember it was only drizzling and it
    was four days apart.
    Now the two 2002 modem incidents made more semce. There was lightning. In
    fact in the second case we had a microburst tornado that took off a few roofs
    and a fence on my block. I put a surge protector on th eentire phone line
    after that.
    If one says once burned, twice shy, what do you say for twice burned? I
    avoid using any plugged-in computer of my own when it rains as a result.
  6. Guest
    I would be interested in your findings of evidence that there is a
    I am currently reviving LCD Tv's from a recycling company I work for
    It is a shame that these tv's are from 2007-2010 and they died
    already.
    I recently joined a good forum for repairs it is
    http://www.badcaps.net/forum/index.php
    Bad caps dot net has many people helping other people repair
    electronics it helped me a lot
    Most of the tv's and monitors I see have blown apart caps and I think
    it is not by chance that they pop
    Sorry if my message is not in correct newsgroup format
    Have been on usenet over 20 years reading but seldom post
  7. Guest
    "I would be interested in your findings of evidence that there is a
    planned failure of software due to ESR "
    https://dl.dropboxusercontent.com/u/29948706/mitsdpps.jpg
    Consider what happens when the ESR of C9015 drops. It looks like it is designed purposely to cause the voltage supply to come out of regulation somewhat at random. You know what happens to certain types of digital circuits when that happens.
    I could understand some form of failsafe because as the ESR or C9015 rises the SMPS will tend to put out more voltage to compensate and keep the voltage at C9016 constant because that is where it's sensed. If you repaired Panasonic VCRs in the past you know what can happen, all the other voltages rise, and I fully understand that this is undesirable.
    If the real goal was to keep the PS from running too high there are many simpler and more effective ways.
    This is obviously not for stability, that's what C9084 and R9014 are for. Note that C9087 is a fairly high value. Playing with the cicuit mentally, like putting a resistor in series with C9015, it looks a bit like an oscillator. Without any DC coupling via the path made by C9087 it would do nothing to actually lower the output of the SMPS, simply make it fluctuate.
    The unit that circuit is in is plagued by software problems requiring software "updates" from the manufacturer. The symptoms would vary quite widely for the obvious reason. When I did the software "updates" I changed C9015.
    What else would corrupt the data, so CONSISTENTLY, in one certain series ofunits ? It may have been better software, possibly with better error correction, but that does not explain C9087 and R9088.
    Knowing capacitors, what happens ? There is a power outage or the unit getsmoved and then it does not work. People might think they broke it in moving and buy another one.
  8. Ah, but edge-lit LED displays are some crazy-ass technology! The way light
    propagates through those things is amazing!
    Mark Z.
  9. Kalyan Ram
    Kalyan Ram Guest
    ://www.web-design-hyderabad.in/seo-course-in-neredmet/
    Contact for advisor : +91 9177522892
    Web Design Hyderabad has a great demand and much more competition, But manyof companies are not able to provide good service for customers, The problem might be because of design quality, not providing dynamic works like contact form or may be client expecting more work with very low cost.
    To work with Web Design in Hyderabad, A designer should more honest with the client, you have to be explain the work of cost exactly, If not a designer will be struggled one day with client, Every one knows a designer can doany work but it takes time right, We have to cost as per our time
    web design companies in hyderabad
    Web design history
    The Hypertext concept was invented by Ted Nelson in 60s, however it was used only for some decades after. During 1992 to 1994 other developers startedadding up their own bits of HTML codes. HTML 1 tags and the HTML 2 born. As internet faster now the Web designers are putting more HTML capabilities.In 1995 more HTML tags have appeared and HTMl 3 was born. Now designers have an lot of option to use HTML B tables and style sheets and many more. They also have animated images, and Flash also introduced. It changed the whole landscape of web design from static to dynamic.
    The first web site published in the World Wide Web history at sometime in August of 1981. It was some 30 years ago, however the Internet born in the sixties. It wasn’t fast as today. However it was capable in transferring information from one computer to another. Tim Berners was the first person who invented the World Wide Web. Tim Berners is British computer scientist. The First website launched in year 1990. on December 25 1990 with the help of Robert Cailliau and young student at CERN, Tim Berners implemented firstsuccessful communication between a Hypertext Transfer Protocol (HTTP) patron and server via Internet.
