2 Stepper motors in sync
Discussion in 'Sensors and Actuators' started by jimmer, Sep 23, 2013.
  1. jimmer
    jimmer
    Sep 23, 2013
    Hi all, I just joined this foum hoping someone can answer this question.
    I want to lift a table at 2 points and keep it level through repeated up/down motions. I am hoping that using 2 stepper motors will be an easy and cheap open loop way to do this.
    No computer control, just an up and down button and microswitches at the limits of travel.
    At first even a simple 'yes, you're on the right track' would be helpful.
    Even better would be pointers to suitable controllers and motors (each one would be lifting 30kg on a 2mm pitch lead screw) and I want a lift of 100mm in about 10 seconds, which works out at about 3W power (or maybe I need 10W at 30% screw efficiency) and 300 RPM.
  2. Fish4Fun
    Fish4Fun So long, and Thanks for all the Fish!
    464
    105
    Aug 27, 2013
    ASS-U-ME ing you use the same input to two stepper drivers, AND the drivers and the steppers are powerful enough you should be able to maintain fairly level open loop synchronization. BUT, WHY? I would use a single motor and either belt or chain drive; OR rails and a single lead screw. Heck, if you are only going 10cm, why not use 4 syringes as hydraulic jacks? (15kg/syringe may be a bit much, but it sure would be cheap to try. look for 60cc-100cc syringes on ebay.)
    The only problems with dual steppers in open loop occurs when for one of various reasons they get more than X steps out of sink. You could remedy this by 1) closing the loop 2) Installing limit switches on both lead screws 3) using a belt or a chain drive and a single stepper (or even just a brushed DC motor). 4) Beefing up your rails.
    2mm pitch is ~12.7 TPI to us slaves of the English system, or more properly 0.07874". I assume you will be using ACME lead screws? A typical stepper motor has 200 steps per revolution. A typical driver will "micro-step" at between 4 and 16 "micro-steps per step". This implies a resolution of 800 to 3200 steps/revolution but the "accuracy" of any given step is typically only +/- 1/2 a step, so the absolute accuracy is ~1/200th of a revolution. 1/200 * 0.07874 ==> +/-0.0004". The real problem is "backlash" which is measured in the number of degrees of rotation a lead screw// nut has to turn after changing directions prior to actual movement. For a high quality lead screw/nut this might be as low as 1 degree (1/360 of a revolution) for a hardware quality lead screw this could be as high as 180 degrees. To make matters worse, synchronizing backlash is virtually impossible.
    This brings us back to rails. If the rails are designed properly, a single lead screw can be used with far better repeatability and accuracy. A lot depends on how accurate//repeatable you need your stage to be. For instance, a high-quality microscope stage with 10cm of travel might cost $10k and have repeatability in the sub-micron range, but it is never going to handle 60kg! An industrial CNC mill might have +/- 0.1mm repeatability over a meter travel and handle a 200kg piece of stock like a kitten plays with yarn, but trying to go from +/- 0.1mm to +/-0.05mm is likely to quadruple the price of the machine.
    The point of all this is careful design includes realistic expectations. If you are using hardware grade lead screws nothing you do is going to get you better than the accuracy of the lead screws. If your rails deflect 2mm then the finest lead screw you can purchase is never going to fix the deflection in your rails. If you are looking for 1mm total accuracy you have to design the entire system so that every part at its worst does not total to more than 1mm of error. The complexity and difficulty of increasing accuracy/repeatability 10x typically costs 10x to 100x. Sadly, even with the best of everything, poor design and/or poor craftsmanship can still lead to poor results.
    Anyway, As for the power consumption calculation of 3W. Steppers are fabulous for a lot of things, energy efficiency is NOT one of them. I would expect a stepper OR steppers to require more like 50W of input power to garner your 3W of load. (And please note, steppers consume considerable power when NOT moving.)
    Fish
  3. jimmer
    jimmer
    Sep 23, 2013
    Thanks for the reply, I should have given more details on the accuracy required.
    This is for a poker/dining table not a precision machine. I only need to maintain level within a few mm not so much for the table but to avoid jamming the lift mechanism. Backlash is irrelevant and for cheapness I'm looking at standard threaded rod.
    I was hoping to be able to do this with a couple of $20 steppers. I found a calculation spreadsheet and it looks more like $40 motors. Not looked at power supply and controllers yet, but once it gets much above $100 a dc motor and belt drive might be the better option.
    edit: just realised I can add gas struts to take nearly all the weight, and then use much smaller motors and drivers.
    So, advice on controllers/drivers still needed please. I'm probably looking to use 12V for power.
  4. Fish4Fun
    464
    105
    Aug 27, 2013
    Hrmm, Try "DC Gear Motor" on ebay. Steppers are going to cost a lot more to use. You should be able to find something for less then $50, perhaps as low as $10 if you don't need too much torque/speed.
    Fish
