T
Terry Pinnell
I'm sure there must be a smarter way to do this than my first design.
I want to produce separate +ve going 12V pulses at the leading and
trailing edges of a low impedance 12V input.
My first draft looks too complex:
- Use R/C/diode edge detector to produce OUT 1.
- Also take input to half a 4013 to produce FF
- Logic NOR the input with the inverted FF
- Use R/C/diode edge detector to produce OUT 2
Here's the timing chart:
http://www.terrypin.dial.pipex.com/Images/2From1.gif
I think those crude output pulses should be adequate without further
cleaning up, as they go to the respective Set and Reset inputs of a
simple 4001 bistable. Of course, squared up outputs would be a bonus;
I might do that anyway if I have any spare 4001 gates.
For the curious, it's an add-on for my curtain controller, to open and
close them either at dawn/dusk or at specific times of day.
Any simpler way to achieve this please?
