2/3/4-digits remote control code for universal remote controller
Discussion in 'Electrical Engineering' started by Scott, Mar 13, 2010.
  1. Scott
    Scott Guest
    What is this remote control code? Is it an international standard or
    proprietary standard? Can someone shed some light onto me as I would like
    to know more detail that is required in my new project.
    Scott
  2. Bill
    Bill Guest
    "Scott" wrote in message
    http://www.sbprojects.com/knowledge/ir/sirc.htm
  3. Adrian C
    Adrian C Guest
  4. Bill
    Bill Guest
    "Adrian C" wrote in message
    Yes and that information is *very* difficult to search for and find, but
    more out there.
    The key word in the search which finds this information is "protocol".
    Otherwise if you search for "IR codes" or "remote codes", you get a ton of
    web pages telling you how to "program" your universal remote so it will work
    with your TV. (The same information which would come with a universal remote
    for the consumer.)
    We of course want to know the *real* codes!
  5. Scott
    Scott Guest
    Thanks for the information about Sony IR protocol. However, what is the
    relation with the universal remote code? When the supplier builds a remote
    controller, they have assigned a code for it. How can they use one or two
    or more for 10-20 models?
  6. Bill
    Bill Guest
    Well the "Universal Remotes" I have seen need to be "set" or "programmed"
    for the TV (or whatever) you want it to operate.
    What they would do is store the codes for each different brand of TV (or
    whatever) in its memory. Then when you set-up the universal remote, you are
    telling it to use that set of codes.
    So at the link above, on the left you can click on codes for other brands of
    electronics. All of these codes would be stored in the memory of the
    universal remote plus more. You just tell it which set to use.
