N
nds
I have a TM4 GPS unit gives o/p as 10 MHz sine wave, 1PPS , 1PPM
signals (100 ms on time squre wave)...
I would like to make the Mulitple of this signals ...
will u suggest me which IC's I should use as a Buffer or which give
multiple o/p
My specific requirement of ic that i should have 50 ohm o/p impedance
so that i will use the RG-58 cable for the further signal Transmission
to diff unit as ref. input.
also i have to convert 10 MHZ sine wave to 5 MHZ and 1 MHz TTL square
wave..
Presently i am using 10E125 for 10 MHZ ECL to TTL converter and then
Processing using IC 7490..kindly suggest me which IC 's i should use
is it better to use ACT IC's ..are they 50 ohm o/p compatible...
multiple o/p
wave..
