1N5822 diodes
john2k
Jun 13, 2012
188
Jun 13, 2012
188
When using a 1n5822 diode, does a small amount of current still get through the direction it's not supposed to? Enough to power something that works on very few milliamps ? Because when I plug in a multimeter in the direction, it still reads a voltage but if I plug in something like a bulb it won't light up.
Harald Kapp
13,719
13,719
This effect is called reverse leakage current. Every semiconductor shows this effect to varying extend.
The 1N5822 datasheet from ST for example shows this parameter on page 2 in the table labeled "STATIC ELECTRICAL CHARACTERISTICS".
It is also shown in the OnSemiconductor datasheet linked by @BobK where it is called "Maximum Instantaneous Reverse Current".
