1N4935 Cross Reference
Discussion in 'Electronic Components' started by [email protected], Feb 3, 2005.
  1. Guest
    Greetings,
    I currently use 1N4935 from On Semiconductor (formerly Motorola). This
    is a thru-hole diode categorized as "Fast Recovery". I'm trying to
    find a surface mount equivalent. I've found a surface mount version
    with Central Semiconductor, but it is not the same. I don't have a
    curve trace, so I have no idea what property it is that I need to be
    exactly the same. I do need 30V minimum. Does anyone know of a good
    cross for this? I've got everything else in surface mount and this is
    the last part. I'm so close, but yet so far, ha ha. Any help is
    appreciated.
  2. Cyrus
    Cyrus Guest
    RS1D has the same specs of 1N4935 with SMA( DO-214AC ) packaging that you
    need.
    Hope this info helps
    Cyrus
