1Mhz -> 1hz
Discussion in 'Electronic Design' started by siva, Dec 19, 2005.
  1. siva
    siva Guest
    to convert the 1 mhz input to 1 hz output, how many no. of D-flip flop
    should i use?
    regards
    siva
  2. Fred Bartoli
    Fred Bartoli Guest
    Approximatly 19,931568569324174087221916576936
  3. PeteS
    PeteS Guest
    Hint for the OP
    Derived, of course, as log[2](1,000,000)
    PeteS
  4. Tam/WB2TT
    Tam/WB2TT Guest
    None. Use 6 divide by 10 counters.
    Tam
  5. PeteS
    PeteS Guest
    Actually, what I should have said is:
    'This is covered in all decent [very!] basic texts. Read one'
    Cheers
    PeteS
  6. Guest
    If you have to ask the question, the honest answer is none - you are
    highly unlikely to get it to work.
    If you learnt quite a lot, you could probably do it with 21 - using 20
    to make a 20-bit counter, which can count up to 1048576, and the last
    one to hold the reset pulse for one period of the 1MHz clock. You'd
    need quite a bit of combinational logic to persuade the D-types to act
    as counters, and some more to initiate the reset pulse at a count of
    999,999.
    Fairly trivial if you buy your D-type bistables in a programmable logic
    chip, otherwise an absolute nightmare to wire up.
  7. PeteS
    PeteS Guest
    If I was doing it in some programmable logic, it might look something
    like
    module OneHzFromOneMeg
    out,
    clk
    output out; // 1 Hz output
    input clk; // 1MHz input clk
    reg [18:0] Count; // half of the count
    reg FinalDiv2; // to guarantee 50% duty cycle
    wire TermCount; // terminal count test
    assign TermCount = (Count == 19'b1111010000100011111)? 1'b1 : 1'b0;
    // detect a count at 499,999
    assign out = FinalDiv2;
    always @(posedge clk)
    begin
    if(TermCount)
    begin
    Count <= 0;
    FinalDiv2 <= !FinalDiv2; // toggle output
    end
    else begin
    Count <= Count+1;
    end
    end
    endmodule
    Pretty simple really, but it requires a basic knowledge of what the
    counter needs to do :)
    Of course, in a real design I would probably add a reset.
    Cheers
    PeteS
  8. D <= Q-bar isn't a lot of combinatorial logic. Just do a ripple
    counter, with Ck(n)<= Q(n-1) and D(n)<=Q(n).
    True, if exactly divide by 1E6 is needed (5% error isn't
    tollerated).
    Programmable logic is the easiest way, but 8-bit counters with
    parallel load and terminal-count can be had (e.g. 74*579). Wire
    the desired count to the inputs and do an and use TC to load the
    count. Details left to the OP.
  9. Guest
    I've never been able to get my hands on a 579 - or any other 8-bit TTL
    counter - when I've needed one. The CMOS 74HCT40103 has been much
    easier to get hold of, though it doesn't have a look-ahead carry output
    (but you wouldn't really need that at 1MHz.
  10. theJackal
    theJackal Guest
    Somebody said 20,21 flipflops .. naw you can use much less . A
    typical divide by 10 counter has 4flipflops and so If you don't feel
    like cracking your brains get 3 divide by 10 counters , cascade them
    and you got your 1pulse/sec signal.
    If you want to design the thing let me know
    "Go easy on the whisky "
    theJackal
  11. Indeed, it's a little early for such.
  12. 3 divide by 10 counters gets 1 MHz down to 1kHz.
    6 divide by 10 counters gets you to 1 Hz, with 24 flip flops.
  13. theJackal
    theJackal Guest
    Six decades oh yeah ... I'd hope to live over that age though.
    its never too late over here .
    theJackal
  14. theJackal
    theJackal Guest
    Yes . Its been a busy day on Mixer theory here ... LOL
    It seems the limit is log10^6/ log12 *4 = 22 flip flops
    "Go easy on the whisky"
    theJackal
  15. You don't need to decode the 999,999 completely, on an 'up'-only
    counter it's sufficient to detect the 1's in the appropriate spots
    with a 12-input AND gate. A 74CH74A @5V is fast enough to do a 1MHz
    ripple counter with some margin to spare (30ns * 20 = 600ns).
    But, I think I'd prefer to do a divide by 15,625 (which only requires
    a 6-input AND eg. 74HC11) preceded by a divide-by-32 to give lots of
    decode time, and followed by a divide-by-2 to give exactly 50% output
    duty cycle @ exactly 1Hz.
    Best regards,
    Spehro Pefhany
  16. Guest
    Spehro Pefhany skrev:
    or use a presetable counter and use carry instead of the ANDs
    -Lasse
  17. Guest
    Not right.
    2^20=1,048,576 - I've recommended using 21 D-type bistables so that you
    can use one more D-type to stretch the reset pulse out to 1usec.
  18. Guest
    If you could find a divide-by-12 ic (they have appeared in the
    data-books, but I don't recall every seeing one stocked by a
    distributor), you'd still need six of them - 24 bistables.
    What it really means is that you weren't thinking straight.
    The real limit is still 20 bistables.
    Unfortunately, I understand it all too well - as well as what you don't
    say because you haven't understood the problem well enough to think it
    through properly.
    The question was restricted to D-type flip-flops, and I've already
    indicated that I'd use one more to produce a tidy reset pulse.
    Obviously, you need combinational logic to make such a counter work.
    You can use propagation delays through combinational logic to produce a
    reset pulse which would be very likely to be wide enough to reset all
    the bistables, but since most logic families don't specify minimum
    propagation delays, you can't always be absolutely confident of the
    reliability of such as system. I've used delay lines to solve this sort
    of problem, but they aren't cheap.
  19. theJackal
    theJackal Guest
    I've seen some on sale on the web
    By writing log10^6/ log12 *4 = 22 flip flops
    I was thinking very straight ... Math stretches right where human
    intuition sometimes fails . As I said ask ... and I will explain.
    By dividing by log 12 i was getting to the maximum number of mod 12
    counters which would be 5. With 5 of those you'd have a frequency of
    1000000Hz /2.48832000E+005 =
    4.01877572E+000Hz left .
    I'd easily handle that with a Mod 4 counter leaving me with
    4.01877572E+000Hz/4 = 1.00469393E+000 Hz which is quite good.
    Total number of flip flops = 5*4 + 2 = 22 flip flops ... which is what
    my simple division of logs up there was saying.
    I was acting in a subtle manner, read above ... it wasn't easy for
    anyone to guess where the math was pointing to!
    Regarding the delays I'd measure them before building the circuit. You
    have at least 4 different types and they can amount to 10's of
    nanoseconds which in terms of frequency is a lot . Mostly depend on
    the technology of the logic families being used.
    Then don't forget clock skews.
    theJackal
  20. Guest
    But 22 flip-flops isn't quite enough, even if two of them aren't in
    divide by 12 packages
    I don't think you mathematical exercise took you anywhere useful
    Hmm - ternary logic? I suspose there might be a way of exploiting the
    fact that a tri-state output can be in three states ...
    I'd love to know what you've got in mind.
    Nothing complicated about where it was pointing - the puzzling aspect
    was why one would want to point the OP that way.
    A pretty good rule of thumb is to assume the minimum propagation delays
    to be one third of the maximum delays, but if the manufacturers don't
    guarantee it, it is risky to rely on it.
    Measuring propagation delays before you build the circuit is sort of
    okay, for a one-off. One very fast TTL system I ws involved with at
    Nijmegen University relied on exactly that, and the engineer go the
    system back about once a year as one of other of the ICs had aged
    enough to take its propagation delay outside the acceptable envelope.
    So the researchers didn't have an ESR machine for a couple of days
    while he shuffled ICs until he'd got it working again. I replaced a
    couple of critical components with ECLinPS and we got rid of almost a
    nanosecond of pattern-related jitter, as well as the really tricky race
    condition.
    I essentially completed the design of a properly toleranced system,
    using a lot more ECLinPS to deliver much better performance, but the
    grant that ran the ESR machine dried up, so it was never built.
