Morris Dovey said:
On 1/31/12 7:34 AM, Jim Wilkins wrote:
You wouldn't believe the amount of time I spent looking at the small
RongFu and Enco small mills trying to figure out if I could manage to
retrofit steppers for a CNC conversion - including that exact machine!
That caught me by surprise. I hadn't realized that you'd been a part of
the great Segway adventure. I hope it was as interesting for you as I'm
imagining!
Segway hired me as a temp after their lab tech injured himself and needed an
operation. At my age no one wants me on their health insurance policy as a
permanent employee. Segway had its good and bad moments like most other
places I've worked. It was a playground more for the mechanical than the
electronic personnel, though I was invited in on a few tiger-team projects
as I am very good at building intricate toys.
Research and development at small companies doesn't give steady long-term
employment. The best I can ask for is to be given a project specification
and be left alone to design and build it. Most places have given me that
freedom.
When the book "The Soul of a New Machine" came out I was in the middle of a
similar project with a similarly highly skilled and motivated team led by a
Feynman-type Ph.D. I was maintaining the overall documentation, designing
and building board test fixtures and writing low-level hardware test code.
Like several other places I've worked a lawsuit during a recession killed
that company.
I've never seen the need for CNC to machine most one-off prototypes. You
still need to know how to operate the machine manually to understand speeds
and feeds and clamping rigidity. Mills make orthogonal plane surfaces and
lathes cut cylinders just fine without automation, and angles or conical
tapers require only simple accessories.
Here is a steering sector gear I made for my tractor using a home-made gear
cutting bit. I've since replaced that worn and ragged rotary indexer.
https://picasaweb.google.com/KB1DAL/HomeMadeMachines#5285710370886636434
https://picasaweb.google.com/KB1DAL/HomeMadeMachines#5285710360947850418
That mill doesn't even have a digital readout. I cut close to final size,
measure, and crank in the difference.
jsw
