1996 Fender deville deluxe 212
Discussion in 'Audio' started by jsnead, Mar 6, 2018.
  1. jsnead
    jsnead
    Mar 6, 2018
    I have a fender deville that is producing extreme distortion on channel 2. Channel 1 is clean and sounds great.I have recently replaced resistor #57 that cleared up an output issue. amp played fine after repair but when owner got amp back this issue developed.
    Any suggestions?
  2. HellasTechn
    HellasTechn
    1,499
    210
    Apr 14, 2013
    Hello and welcome to our forum !
    A more detailed explanation will be essential before we can issue assistance since we dont know exactly what you have or what you have done to it. For example: brand, model, schematic if possible (or link to it), photos of the board if possible. That way our suggestions will be better aimed.
  3. bushtech
    bushtech
    935
    145
    Sep 13, 2016
    This might give you some clues:
  4. 73's de Edd
    73's de Edd
    2,805
    1,176
    Aug 21, 2015
    How do you get this channel 2 reference ?
    The unit is a mono amp and the only 1-2 aspect is the two inputs 1 and 2 and they then tie into the same common input junction .
  5. Geoffrey Barber
    Geoffrey Barber
    Feb 26, 2018
    Hi, The Fender Deville (like all modern 2-channel guitar amps) has been designed so channel 1 is the clean channel and channel 2 is the overdrive or distorted channel. Again on most modern guitar amps you will find 2 input jacks one jack is designed for standard or non active guitars and the other for active guitars, nothing to do with channel 1 or 2. If you plug a standard guitar into say input jack 1, it will sound louder than input jack 2, this is because input 2 will attenuate the input signal by half to accommodate an active guitar which give double the output.
Similar Threads
Loading...
