N
N_Cook
In a German Minifon P55 from the 1950s , pocket size wire tape recorder ,
even more surprisingly with a capabilityof 5 hours of continuous recording
If disbelieving , Excellent pics etc of one on
http://vintage-technics.ru/Eng-Minifon_P55.htm
Anyway part of the complex drive mechanism is a steel barrel (with torsion
sprung pulley at the centre so when it stops, the mechanism rotates
backwards to reset the end-stop trigger position).
The barrel has an axial 1.2 mm diameter pin each end that sits in an end
anchor of a hollow brass cylinder each end . These cylinders have a sprung
loaded pin inside them but there is no sign of any bearing material. Running
lubricated there is too much resistance to rotation. Robbed a pair of 1.1mm
balls from the tiny ring bearing inside a scrapped VCR pinch wheel. But
there is only 1mm or so of springing at either end so again not free
turning.
What may have been in the ends in the 1950s.?
I will next try rolling a ball of PTFE tape or a 1mm disk punched from PTFE
but what would have been in there , bearing in mind German engineering so
would not have been steel faces bearing crudely against steel at either end
, surely?
turning.
, surely?
