Categories
Platforms
Content
The power required (320W) could be within the range of a computer power supply and one of these could be modified to give the higher voltage.
I assume it a battery bank? If so why not do as others have suggested and tap off the appropriate point on the bank.It is from the battery....
A computer power supply rectifies the mains to give a very high DC voltage which is then chopped and fed to an inductor/transformer to get lower voltage and this is then rectified to give DC output at various voltages.
It would be feasible to rewind the inductor to give the voltages that you desire and fit suitable rectifiers and capacitors. Not a simple job for a novice.
Then why not just use 80v worth of the batteries..???
Both the stated voltages are non standard. What exactly are you planning to do?
stores the solar energy in a battery, which ouputs 200vdc
