stinkingdog101
- Sep 19, 2010
- 1
- Joined
- Sep 19, 2010
- Messages
- 1
I am using two 18 volt cordless drill batteries to power a 12 volt trolling motor. It is a low budget toy that I am assembling out of PVC pipe . I want to be able to use a timer on this motor that will not exceed 5 minute run time. As you can see I have a disparity between the voltages > although the motor seems quite happy at 18 volts. I saw a timer on Ebay that is a DEI 528T adjustable 12 volt pulse timer but the timing only runs up to 90 seconds. This seems idea with the exception of the run time. I need at least 1 to 5 minutes adjustable. ALso the voltage is wrong. Any ideas as to how I ca get this home built project off the ground would certainly be appreciated.
