flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
18 pin DIL IC SH69P 20C 1217.E 018DU N6SNY-3-3
Found inside touch-operated timeswitch. Looking for info?
maybe this..
http://datasheet4u.com/datasheet-pdf/SinoWealth/SH69P20C/pdf.php?id=932009
http://www.dycmcu.com/data/upload/201402/081654408.pdf
Any other info gratefully received.
It's being used to control a relay on a timeout. Press a button, relay comes on, it starts counting down, after an adjustable preset time, relay goes off.
The full device is a wallswitch-sized affair labelled 'Lowenergie Multi-Use 16A Touch Timer Switch.
Unfortunately I can't find a pdf online of the manual sheet that came with this exact timer, but this one is very similar just to give a vague idea:
http://docs-europe.electrocomponents.com/webdocs/03be/0900766b803bee89.pdf
The device can time up to 2 hours. I'm hoping to be able to modify the circuit to extend the timeout up to 24 hours if possible.
maybe this..
