16f84 pic prog pinout
HI,
I''m trying to programme a 16F84A PIC throught IC-Prog with an
interface that I built, I have some questions :
I'm not sure which are the pin on 16F84 PIC, MCLR is ok, but for :
Data I/O : Is it RB7 ??
Clock : Is it ClkIN, ClkOut or RB6 ???
And while I'm testing hardware I get 5v on low state and 12 volt on hi
state for MCLR, is this correct ? If not what are the right voltage ???
Robin
[email protected]
F
Frank Bemelman
HI,
Jezus Christ, is it so difficult to download a datasheet
for that ancient 16F84?
B
Bob Eldred
HI,
Robin
[email protected]
Vdd-pin14, Vss-pin5, MCLR\-pin4, RB6-CLK-pin12, RB7-DATA-pin13. Refer to the
programming manual for the correct voltages and timing.
I refered to the datasheet, And I finally got all information exept for
min values of MCLR, I found that programming is enabled while MCLR is
12v, but I still don't know if it 5v on low level is correct...
Anyway, thanks !
W
Wouter van Ooijen
Information about programming is not in the datasheet. Get the
programming specification.
Wouter van Ooijen
http://www.voti.nl
Webshop for PICs and other electronics
http://www.voti.nl/hvu
Teacher electronics and informatics
