16F628 in circuit programmer
Discussion in 'Beginner Electronics' started by [email protected], Aug 7, 2005.
  1. Guest
    I've been looking at in circuit programs for a new project I'l like to
    start. I reckon I'd need a in circuit programmer as I'm new to the
    16h628 and would probably compile my code a few hundred times before it
    works :)
    I've been looking at wisp628 (http://www.voti.nl/wisp628/index.html)
    and it looks like the ideal thing. One question I have though is it
    looks like you need a programmed 16f628 for the actual programmer. Do I
    now have to build a programmer to program the 16f628 so that I can use
    it in the in-circuit programmer?
    Can anyone shed some light on this? Is it a good way to do projects?
    Should I be looking at something else?
    PS This is for a hobbiest project so whatever I need I'd like to build.
  2. Alexander
    Alexander Guest
    Try an LVP Cable
    http://home.vrweb.de/~lotharstolz/stolz.de.be/lvpc/index.html
  3. Guest
    Thanks - I'm off to the electronic shop :)
  4. Alexander
    Alexander Guest
    Perhaps someone in this newsgroup has a webshop and can sell you something
    (see wouters post and website).
  5. Rich Grise
    Rich Grise Guest
    No, you buy the one that comes with the kit, like it says in the first
    line of their website, right after the header.
    So, yes, you'd have to buy something.
    As long as the circuit itself is already designed, it should be fine.
    They tell you how to design your project so that the ICP just plugs
    into it.
    With a standalone programmer, you wouldn't have to build your
    circuit in advance - you could breadboard it.
    Then again, I suppose you could plug the ICP into the right pins
    on the breadboard.
    Yeah, go for it. :)
    Have Fun!
    Rich
