+- 15V regulator
Discussion in 'General Electronics Discussion' started by peterluke, Oct 22, 2013.
  1. peterluke
    peterluke
    4
    Oct 10, 2013
    Hi Folks:
    I've a 24VDC input and need to generate a +/- 15VDC for a microphone preamp circuit, just wondering what else I can use other than 7815-7915 regulator combination.
    Cheers!
  2. davenn
    davenn Moderator
    13,676
    1,892
    for a split rail supply you generally need a centre tapped transformer to produce the 0V rail .... do you have this ?
  3. (*steve*)
    25,419
    2,790
    +/- 15V works out to be 30V in total, so it's not obviously sufficient.
    From the 24V you can generate +15V easily with a 7815
    The negative rail needs to be generated by something that can invert the voltage.
    I don't suppose you have access to -24V as well do you?
    Given it's for a preamp, I suspect that the current requirement will be low. This suits something like a simple switched capacitor circuit.
  4. davenn
    davenn Moderator
    13,676
    1,892
    welll DOH
    Thanks Harald
    yeah I misread the input its supposed to be AC input
    Just having a "senior moment"
    I go stand in the corner :(
  5. (*steve*)
    25,419
    2,790
    How does that work with DC input Dave?
  6. peterluke
    peterluke
    4
    Oct 10, 2013
    Hi Folks:
    Thanks for the reply, the 24 VDC is for the microphone phantom power, I'm using a INA217 which requires +/- 15VDC, I could go to 48 VDC but adapter is hard to find.
    Cheers!
  7. solo2racr
    solo2racr
    142
    Aug 21, 2013
  8. Harald Kapp
    10,615
    2,373
    Dave, your circuit doesn't generate -15V from a positive DC input. Nor can it create +15V from a negative DC input. Your circuit would require an AC input.
    Soloracer: your link points to a circuit which uses AC input (transformer). Peter only has Dc available. Therefore a means to generate the negative voltage from the positive voltage is required. Depending on current requirements, a switched capacitor circuit as suggested by Steve could be suitable. look up e.g. MAX660 or LTC1054 or Google "switched capacitor voltage inverter".
