+/- 15 volt dc power from battery
Discussion in 'Power Electronics' started by JusticeHere, Jun 7, 2017.
  1. JusticeHere
    JusticeHere
    Jun 7, 2017
    If I have a +/-15 volt dc power supply requirement for an instrument, how can I supply that instrument the required power with batteries? Any ideas for suppliers you can order small quantities from the internet would be helpful as well.
    Thanks!
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    You need more data.
    I suggest that you use four 9V batteries and a 7815 positive regulator and a 7915 negative regulator. The batteries must be big enough to provide the current.
  3. BobK
    7,682
    1,688
    10 alkaline cells for each polarity also works.
  4. JusticeHere
    JusticeHere
    Jun 7, 2017
    How would the wiring work for the two battery packs? The input wiring is +15v, -15v, and common.
    Thanks.
  5. davenn
    davenn Moderator
    13,902
    1,971
    the zero/common rail comes off between the 2 packs and from that pretty obvious when the negative and positive rails come from
    bushtech likes this.
