15 v power cord
Discussion in 'General Electronics Discussion' started by Kasey, Dec 21, 2017.
  1. Kasey
    Kasey
    Dec 21, 2017
    I need a 15 v 500ma power cord. I found onw but will it work. It 15 v but 550 MA instead of 500ma. I need to know will this power cord work on my peakey mixer?
  2. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    You should have no issues using that. Your mixer will only draw the current it needs.
    Cannonball likes this.
  3. Audioguru
    Audioguru
    2,725
    614
    Sep 24, 2016
    Does the mixer need 15VAC or 15VDC? They are completely different and the mixer will probably blow up if the wrong one is used. If it uses DC is the polarity correct? If the polarity (positive wire and negative wire) is backwards then the mixer will probably blow up.
  4. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
  5. Audioguru
    Audioguru
    2,725
    614
    Sep 24, 2016
    Here you said you need 15V but at Digikey you said you want 12V. Why the difference?
  6. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    The Digi-Key one was just showing how to select one in general. Things to look at. Not this specific supply.
