R
RMD
Before I start let me just say a few things to establish where I'm
coming from.
I lived in the Adelaide foothills for many years. In summer we used to
get the gully winds (gully gales, really) which would cool the house
overnight. I had a desk fan to stir the air up in the house in the
afternoon. (Btw I bought this desk fan in 1969 at a 2008 equivalent
price of $600 - fans in 2008 are $10-$20.) The house had wide eaves
and no sun on windows and was generally of good thermal design.
I had refrigerated air conditioning at work. It ran 24 hours/day in
summer and worked well, though one sensed it was wilting towards the
end of a heat wave as all the bricks and concrete of the building
"cooked up". It must have cost many hundreds of dollars per week to
run in a summer heat wave.
I then moved onto the Adelaide plains into a stone and brick house
with concrete floors. Being of heavyweight construction with very
thick walls, the house thermal performance was very good. I added
blinds to keep the sun off windows.
Single hot days were a breeze, and the house remained cool inside.
Heat waves were not so good, and after 4 days the house was getting
hot inside. The house would then take a couple of days to cool down.
30C inside during longer heat waves was common, and I did see inside
temperatures as high as 33C and 36C in exceptional hot weather.
I increased the fans used around the place, since fans were now cheap,
and added window fans to bring in the cool night air. This worked fine
until temperatures overnight would reach 30C, when there was no cool
night air. Luckily this wasn't a frequent occurrence.
The thought of fitting air conditioning was present. However, I didn't
want to spend a bomb on something that wouldn't be used a lot in a
normal year.
Whole house refrigerated air, like at my workplace, was out as far as
I was concerned because of the high expense of both the installation
and operation. I had much better things to spend my money on.
This left the alternatives of putting in a split system in my bedroom,
and perhaps another split system elsewhere in the house, or fitting
whole-house evaporative air conditioning.
Thinking about the pros and cons of these alternatives always ended up
with me doing nothing - summer would then end and the problem would go
away for another year.
With the split system idea I hated the idea of trying to choose where
I might cool the house. Wherever I cooled would be wrong some of the
time, and the thought of being stuck in a couple of rooms over a
heatwave made me feel stir-crazy just thinking about it.
And even the people who had evaporative air conditioning seemed
apologetic about it….. (Though Adelaide's low humidity summers were
ideal for evaporative air conditioning.)
Finally I took the plunge and fitted ducted evaporative air to my
house for a whole mish-mash of un-connected reasons. The unit cooled
my whole house, and including the attached garage by opening the
garage access door and letting the air exhaust over the top of the
roller doors.
As you may know we had a record 15 day heatwave in Adelaide recently.
Air conditioners caught fire due to the constant running, and one
house was totally burnt out after the ducting delivered fire
simultaneously to every room. (Domestic air conditioners aren't rated
for constant operation apparently.)
Well, my new evaporative air conditioner performed brilliantly under
these exceptional conditions.
I sometimes ran it 24 hours/day. The house was at 22C every morning at
the start of the day, and it might reach 25C in the afternoon.
The a/c cost about $4/day (cost of water plus electricity) to operate
- a very low cost to cool the whole house plus the garage. An
equivalent refrigerated unit might have cost up to $300/week to run.
I checked how my former work place was going about 10 days into the 15
day heatwave. With my house thermometer showing 25C the temperature in
this workplace "no-expense-spared refrigerative installation" was 24C.
I had a friend who had a household zoned refrigerative air
conditioner. This air conditioner wasn't operated constantly because
of the operating expense. The house internal temperature was 27C.
Outside the zoned area the house was like a furnace
Another friend had an appropriately sized wall unit in a living area.
Again, the house internal temperature was never below 27C after 10
days of heat wave. Outside of the cooled area the heat was intense.
Now, I realize that air conditioners are one of those things that
really divides people. And that for many then evaporative air
conditioners just aren't "real" air conditioners. So I don't expect
to change many minds on this.
And yes, I'm aware evaporative air conditioners don't work on the rare
(in Adelaide) high humidity days.
However, my evaporative unit worked brilliantly over a 15-day heat
wave. In fact it worked virtually as well as a no expense spared
refrigerative unit - which no one could afford to run in a domestic
setting - and far better than the usual more economical domestic
refrigerative air conditioners. Apart from still feeling a bit
stir-crazy from being stuck in the house I was comfortable the whole
time.
I'm a convert.
Ross
coming from.
normal year.
roller doors.
time.
I'm a convert.
Ross
