12VDC Sp rocker can I use it on 24v circuit.
Discussion in 'General Electronics Discussion' started by JPU, Aug 16, 2012.
  1. JPU
    JPU
    281
    May 19, 2012
    Hi All
    I have this switch
    http://www.maplin.co.uk/12v-illuminated-rocker-switch-218983
    However I have a 24V (21.5v - 29V) LIPO battery. Is there a way I can get the light to illuminate in the switch without blowing it, i.e can I use a resistor and if yes how, which one???
    Many thanks for your help.
    JPU
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    If it is a standard fitting bulb, it can be changed for a 24V one. A 28V bulb would last longer.
  3. JPU
    JPU
    281
    May 19, 2012
    hi,,
    The switch can not be opened,,thanks anyway..
    JPU
  4. shrtrnd
    shrtrnd
    3,827
    520
    Jan 15, 2010
    Besides over-voltaging the switch, you have to know the amperage. If you've got a
    high amperage circuit it'll play hell with the 12V switch if it's not designed for the
    amperage you're passing through it. (It SHOULD be listed on the switch itself someplace).
  5. CDRIVE
    4,960
    652
    May 8, 2012
    This appears to be a single pole switch with three pins, so I think it's wired like one of these but more likely to be the incandescent. Measure the lamp current @ 12V and we can go from there.
    Chris
  6. CDRIVE
    4,960
    652
    May 8, 2012
    It's rated at 10ADC.
    EDIT: It doesn't state if it's 10ADC or AC. It should though!
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    The datasheets are horrible, probably some mass produced Asian switch and the reseller just tossed together a cheap datasheet...
    *Edit confirmed they are just a distributor, if you download the catalog from the "Alan Butcher Components Ltd" website they state such... I'll bet if you track down the real manufacture of the switch ( Molveno OEM, out of Italy) you will garnish a lot more information about it...
    The 33FB datasheet says 12VDC 10A
  8. JPU
    JPU
    281
    May 19, 2012
    Hi Chris
    The lamp current at 12V is .038A
    JP
  9. CDRIVE
    4,960
    652
    May 8, 2012
    A 330Ω resistor in series with the lamp pin should do it.
    Chris
  10. CDRIVE
    4,960
    652
    May 8, 2012
    Nice bit of sleuthing CC.
    Chris
