U
Uriah
I have a 12VDC wiper motor that is being used in one of those animal
cranes as a drive for a platter. It stopped working and I have taken
it apart and am stuck. What it does is that it works for about a
minute then starts slowing down and then stops. If I turn it off and
wait a minute it will do it again. There doesn't appear to be any
shorts on the wires wrapped on the inside. I am a little confused on
how this thing works. It has three brushes, two are opposite at 12:00
and 6:00 and one wired to the frame is at about 8:00. There are also
two blue Varistors??? wired between the ground and each brush, at the
input plug, not in the motor. They have CNR written on them and then
100820k under that. What are they used for? And why the three brushes
in that kind of configuration? And... how are you supposed to wire
these up? being that there are three brushes? And why does it stop
running. The manufacture in AU said that it was losing magnetic
power??, is that possible? They want over $300.00 for a direct
replacement. I found surplus motors that are close for $20.00. Any
help on this one? Thanks so much
Russ
Russ
