12vac to 12vdc
Discussion in 'Electronic Design' started by s cass, Aug 6, 2003.
  1. s cass
    s cass Guest
    12vac to 12vdc?
    how to ?
    12vac from 12vac landscape lighting transformer 100 to 200 watts
    to
    12 - 24vdc .350ma
    thanks
  2. Fred Bloggs
    Fred Bloggs Guest
    Use a voltage doubling rectifier and filter capacitor hookup to drive a
    National LM2675-ADJ simple switching regulator. See the "Power" section
    at http://www.national.com for more detail and to run a simulation.
  3. TCS
    TCS Guest
    Do you mean a fullwave rectifier? Voltage doubling is an entirely
    different beast.
    No need for a switching regulator either. A 7812 will do the trick
    just fine. 12Vac=~17Vpeak; the 5V extra is plenty to cover the 7812's
    voltage drop.
    Summary: 12vac -> full wave rectifier -> cap (500uf or so) -> 7812 =
    12VDC
  4. N. Thornton
    N. Thornton Guest
    Hi.
    Just one additional point: transformer regulation. IRL you can expect
    10% more voltage out because your 100w transformer is only lightly
    loaded.
    You wont need any regulator if youre happy with 16-19v rather than
    12v.
    Regards, NT
  5. Fred Bloggs
    Fred Bloggs Guest
    I was taking the "12 - 24vdc .350ma" in the body of the post to mean he
    wanted an adjustable output over that range. Now it is becoming clear
    that the OP has copied labels he sees on some some junk he owns- since
    nothing adds up.
