Hi
I am making a simple voltage regulator using a TS7805 , as per the diagram attached , to light up some led's in a PC Gaming machine I am building , can I fit another spec of capacitor instead of the ones shown :
1x TS7805 5 volt regulator
2x 1uf capacitor
1x power plug (or other connector)
1x 220 ohm resistor
1x Blue LED (I used a diffused one)
I have plenty 16v 22μf capacitors ! , I have seen simular voltage reducers using a TS7805 and using different spec capacitors .
question : how do you work out in that simple circuet what size capacitors to use .
cheers
spike
2x 1uf capacitor
1x 220 ohm resistor
cheers
spike
