[email protected]
One problem here hopefully I can get this to work..
I wired a an automotive relay to drive a 12VDC RV water pump.
from a power supply,
12V+ going to 30 and 87 output to pump.
split same 12V going to coil +
ground going to the pump directly
split same ground going to the pump and also the coil -, I put a
switch inline with this wire to turn the relay on and off.
I am not sure which one 85 or 86 for the coil, it should not matter?
When the switch is on, coil is energized and supposed to connect 30
and 87.. but the problem is that the relay clicks on and off
repeatedly.
The relay does say negative spike suppression, is this the problem or
do I need some kind of isolation, I have not wired up a relay sharing
the same 12V before...
Another thing may be the pump has a strong startup surge and dropping
the power supply voltage, but I am not sure.
repeatedly.
