A
ahonda55
I have LTSpice Switcher CAD III , is it what what you mean
I have LTSpice Switcher CAD III , is it what what you mean ?
it doesn't matter , i fact i made anothe freq.>voltage circuit like
the one in paul's page.
I use it now , but i can use anything else , electronic parts are
cheap here!!
Understood.
YES
Okay.
i got that from Paul's page , and it is logically true.
i still can't find any info. about it , but it is safe to play.
i have tested the LM2907 circuit with the transistor - relay circuit
in my car yesterday , i got that the response should be slow to let
the engine RPM go down.
thanks , i have tryed it but nothing happenned.
thank you very much , i don't have it but i will try to search for
it.
i have now in my car 20 LED's tachometer ,, here is a photo for the
circuit....
http://img146.imageshack.us/img146/868/dsc044706zn.jpg
Thanks a lot , your answers are more that my expectations, really
thanks , i know that i have asked too many questions but i have
learned so many things from you.
I take it that the solo LED color is for 4500 RPM?
Jonathan said:
ahonda55 said:should.
Terrific! I assume this is the replacement relay:
http://www.lmrelay.com/jzc-22f-en.htm
They don't show the LR-22F on the site, thus the
assumption. If the assumption is correct, it draws
~ 37 mA so the transistor in the 2907 should handle it.
To be sure, measuring the current draw is indicated,
since the spec is based on assumption.
Thanx a lot , but i still have the same problem.
when i open the html file by notepad and in Courier font Or when i
copy the schematic and paste it in the note pad in Courier font the
result is the same....
all the lines starts at the left edge of the window !!
i know that i will miss a lot and that is why i have to scream !!
thanks a lot and if you have another way to see the schematic plz
share us
Thanks again.
Jonathan said:That looks right. Do you know, off hand, how you arrived at that 37mA
figure? Is it on the assumption of the larger .45W number on the
sheet where it says 'resistance' and taking that as wattage with the
expected 12V specification? Namely, .45/12?
Jon
ahonda55 said:Thanx a lot , but i still have the same problem.
share us
Thanks again.
Try saving the file as a text file instead of an htm
file and see if that works for you. If it does not wor
you will have to change the settings in your newsgrou
reader. If you tell us what newsgroup reader you use
someone who has the same reader can tell you how to se
it u
I sent you an e-mail with the .jpg attached showin
the 741 connected as discussed in the thread
i did that , and the same problem still. i use Internet Explorer 6.
ahonda55 said:thanx man , i got your e-mail .
and i have only IE6 , i don't use Outlook Express .
all i have is IE6.
Thank you
all i have is IE6.
Thank you
Ok - I forwarded the original note and jpg.ahonda55 said:well ,,, i got your idea now , i have no idea befor !!
yes , there is
1- Microsoft Outlook (default)
2- Outlook Express
Ed , i want to ask you another small thing and sorry for asking so
many things,,, would you please send me the 741 explain and the
example like you did in the first e-mail , for me and for all to know
, cuz that was a perfect explain to use the 741.
Thank you again and again .
