12v motor run off battery charger ?
Discussion in 'Power Electronics' started by auscab, May 18, 2011.
  1. auscab
    auscab
    May 18, 2011
    Hi all,
    I want to make a mechanical wood cutting device powered by a second hand 12v windsceen wiper motor, I
    I would like to know if it is ok to do this with a 12v lead acid battery charger ? I am in Australia on 240 V power
    The battery charger I have is made by yk and on the front says
    YK -c1212 Automatic charger
    There is a charging indicator light and a power on of switch.
    On the back
    240 v 280 W
    Q0161
    n2007
    There are Two fuses , above these it says
    15A 32 V 4at 250V
    I gave it a try and it ran the motor,but would just like to know is it safe ?
    I would want to run it for an hour or two at a time, or is ther another way this should be done ?
    regards Rob
  2. auscab
    auscab
    May 18, 2011
    problem solved.
    I found out today there are auto stores that sell power supplies that do the job,
    and that battery chargers are not the way to go.
    cheers Rob
