12V DC Motor (RS-550PC-8516) had some problem
Discussion in 'Sensors and Actuators' started by norm, Sep 10, 2016.
  1. norm
    norm
    Sep 10, 2016
    when i connect my 12v dc motor to a 12v battery it produce lots of spark and dont really work...anybody know why is it happening?
  2. Bluejets
    Bluejets
    3,995
    826
    Oct 5, 2014
    Probably because you've cooked it.
    The PC in the part number refers to 7.2v motor.
    I'll bet you had some revs out of it for a short time....:eek:
  3. norm
    norm
    Sep 10, 2016
    the local store suggest me the dc motor and battery so i just follow them :/
  4. Alec_t
    Alec_t
    2,788
    742
    Jul 7, 2015
    Then get the store to replace the motor for free.
  5. Minder
    Minder
    2,948
    623
    Apr 24, 2015
    The max suggested for that motor is 9.6vdc if you need 12v operation you need the VC version good for 14.4v.
    M.
  6. duke37
    duke37
    5,342
    753
    Jan 9, 2011
    If there are sparks, then it is probably a brushed motor with the brushes rubbing on to the commutator. Sparks will occur when the contact is not good such as when the brushes are worn out. Worn brushes can be replaced They can also occur when the armature is damaged and there are large voltages between commutator segments. In this case the motor is dead. Check that there is no sparking damage between two adjacent segments.
