12v ac and 12dc-10a output rectifier circuit
suryaurza
Nov 15, 2013
5
Nov 15, 2013
5
we want a circuit of rectifier which provide 12v dc-10A ouput at 12v ac input?
Harald Kapp
13,700
13,700
AC 12V normally is the RMS value.
The peak value of the AC is sqrt(2)*Vrms=16,9V.
During each half wave two diodes in the rectifier are active. Each diode drops ~0.6V. Therefore the peak output voltage is 16.9V-2*0.6V=15.7V.
The output voltage will drop while current is drained from the capacitor - at 10A rather fast.
Here is a tutorial that tells you how to do the necessary calculations.
suryaurza
Nov 15, 2013
5
Nov 15, 2013
5
can you provide another rectifier circuit which give 12v dc- 10A output when give 12v ac input?
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
What is this going to power?
Chris
